[GRASS-dev] Re: GRASS6.4.1
    Markus Neteler
    neteler at osgeo.org
    Mon Nov 22 15:35:13 EST 2010
On Mon, Nov 22, 2010 at 12:11 PM, Benjamin Ducke
<benjamin.ducke at oxfordarch.co.uk> wrote:
> Would it be possible to also sync r.in|out.gdal
r.in.gdal: already identical
r.out.gdal: only %f changed to %g many times (I would not backport to
not ruin all translations
> and v.in|out.ogr from 6.5?
v.out.ogr: contains your improvements, not yet backported (has it been
sufficiently tested?)
v.in.ogr: contains this relevant fix (?):
diff -ru '--exclude=.svn' grass64_release/vector/v.in.ogr/geom.c
grass65_release/vector/v.in.ogr/geom.c
--- grass64_release/vector/v.in.ogr/geom.c	2010-10-09 21:50:43.489449120 +0200
+++ grass65_release/vector/v.in.ogr/geom.c	2010-09-22 09:25:14.917974961 +0200
@@ -301,9 +301,9 @@
 	    otype = GV_BOUNDARY;
 	if (split_distance > 0 && otype == GV_BOUNDARY)
-	    split_line(Map, otype, Points, BCats);
+	    split_line(Map, otype, Points, Cats);
 	else
-	    Vect_write_line(Map, otype, Points, BCats);
+	    Vect_write_line(Map, otype, Points, Cats);
 	/* Isles */
 	IPoints =
If no objections, I can backport v.in|out.ogr from 6.5 to 6.4.
Markus
