[GRASS-dev] [GRASS GIS] #1222: v.rast.stats returns error: global
name 'vector' is not defined
trac at osgeo.org
Wed Nov 24 04:10:39 EST 2010
#1222: v.rast.stats returns error: global name 'vector' is not defined
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: v.rast.stats | Platform: Linux
Cpu: x86-32 |
Command
v.rast.stats -e input=ma3935 at CHRIS raster=5703_14r at CHRIS colprefix=ma_14
returns error: global name 'vector' is not defined.
GRASS 7.0 compiled from weekly source grass-7.0.svn_src_sn
apshot_2010_11_20,
OpenSUSE-11.1 Linux 2.6.27.54-0.1-pae;
Intel Pentium 4 CPU 3.00GHz
./configure --enable-shared --with-postgres --with-gdal=/usr/local/bin
/gdal-config --with-postgres-includes=/usr/include/pgsql/ --with-postgres-
libs=/usr/lib/postgresql --without-freetype
Raster map:
Type of Map: raster;
Data Type: CELL;
Rows: 744; Columns: 744;
Number of Categories: 10599
Vector map:
Type of map: vector (level: 1);
Number of points: 0; Number of centroids: 1;
Number of lines: 0; Number of boundaries: 7;
Number of areas: 0; Number of islands: 0;
Map is 3D: No;
Number of dblinks: 1
The vector area is inside the raster map.
The full command output is in the attached file.
Thank you!
Andres Kuusk;
Tartu Observatory, Estonia;
andres at aai.ee
Ticket URL: <http://trac.osgeo.org/grass/ticket/1222>
