[GRASS-dev] Added suppress_required field to flags
Martin Landa
landa.martin at gmail.com
Thu Nov 25 16:03:37 EST 2010
2010/11/25 Glynn Clements <glynn at gclements.plus.com>:
> However, this feature cannot be used until the GUI's own requirement
> checking has been adapted to understand it. Currently, if an option
> marked as ->required is omitted but a flag marked as
> ->suppress_required is given, the command itself won't complain about
> the missing option but the GUI will.
> The field is included in the --interface-description output; the GUI
> just needs to be updated to make use of it.
done in r44422.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
