[GRASS-dev] r.sim.water in 64, 65, 7
Glynn Clements
glynn at gclements.plus.com
Fri Nov 26 12:43:27 EST 2010
Helena Mitasova wrote:
> GRASS64: it runs on linux, but gives Segmentation fault on Mac and Windows
> Glynn has fixed the segmentation fault problem in GRASS7, I believe it is r42402(?)
r42402 shouldn't have any effect upon the resulting binaries; it just
cleaned up the source code. The only other changes I've made to that
code were related to library changes.
