[GRASS-dev] CLI!=GUI
Francesco P. Lovergine
frankie at debian.org
Mon Nov 29 12:18:14 EST 2010
On Sun, Nov 28, 2010 at 09:29:28PM +0000, Glynn Clements wrote:
> Hamish wrote:
> > > > If the only available packages (RPM, .deb, etc) insist
> > > > upon installing GUI libraries, complain to the people who
> > > > make the packages.
> > Paolo:
> > > OK, so, now I'm complaining ;) : packagers, please have
> > > your saying here.
> > disk space is very cheap. package maintaining time is not. IMHO
> > unused libraries & a couple extra packages do no real harm
> It isn't "a couple". Once you link against wx, you're looking at ~60
> extra libraries.
> I'd suggest that the core GRASS package shouldn't list X, wxWidgets or
> (in 6.x) Python as dependencies.
> It shouldn't be necessary to split the actual GRASS distribution into
> GUI and non-GUI components. Put everything in the non-GUI package, and
> have a separate GUI package which is empty (or contains a single dummy
> file if the packaging system doesn't allow empty packages) and exists
> solely to hold the GUI-specific dependencies.
As said in another mail of mine, it is not a problem brute-splitting GUI
dependencies (e.g. current squeeze release for 6.4 only *suggests*
wxpython dependencies). Moving GUI-related binaries in different
packages is a pain to maintain, but theoretically it can also be done.
It remains a brute hack anyway, which is a symptom of
a fundamental design problem: the whole system is theoretically
layered and modular, but in fact it cannot be really componentized
in a *clean* way. Something I find basically disturbing and not
elegant, sorry my purism.
BTW, I tend to disagree about considering GUI maintainance not influent
in the releasing cycle. It *is* influent and caused many of the
past/present windows/macos delays. Having a sort of grass-toolbox
and grass-gui sub-projects could help a lot (like CNES does
with OTB and Monteverdi).
And like it or not, there are people that do not use the
default GUI or a GUI at all. Splitting would gain consensus
about the core, which is IMVHO the true value of GRASS.
Of course, my 2 cents, as always.
