[GRASS-dev] [GRASS GIS] #1189: wingrass: 'g.region -l' fails
GRASS GIS trac at osgeo.org
Wed Oct 6 05:17:37 EDT 2010
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  6.4.1
Component:  Packaging  |     Version:  svn-develbranch6
 Keywords:  g.region   |    Platform:  MSWindows XP
      Cpu:  x86-32     |
 on a new wingrass 6.5svn nightly build, in the spearfish dataset,
 'g.region -l' fails with an error.
 ERROR: Unable to update lat/long projection parameters
 running again with `export PROJ_DEBUG=5` on the msys rxvt terminal line
 shows:
 pj_open_lib(proj_def.dat):
    call fopen(c:/Program Files/GRASS-65-SVN/etc/nad/proj_def.dat) - failed
 (in the wingrass builds that file is in $GISBASE/proj/)
 $PROJ_LIB is already set by the startup script:
 GRASS 6.5> echo $PROJ_LIB
 C:\Program Files\GRASS-65-SVN\proj
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1189>
