[GRASS-dev] Re: [GRASS GIS] #1166: r.tileset: projection string
munching on wingrass
trac at osgeo.org
Wed Oct 6 05:26:42 EDT 2010
#1166: r.tileset: projection string munching on wingrass
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: r.tileset, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hamish):
m.proj is another one that fails.. wingrass 6.5svn daily build from the
last day or two, Windows XP Pro from MSys's rxvt, in the spearfish
dataset:
GRASS 6.5> export PROJ_DEBUG=5
GRASS 6.5> echo "-103.75|44.5" | m.proj -i
input parameters=[+proj=longlat +datum=WGS84]
output parameters=[ '+proj=utm' '+zone=13' '+a=6378206.4'
'+rf=294.9786982'
'+no_defs' '+nadgrids=c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus' '+to_meter=1.0']
* * 0.00
pj_open_lib(proj_def.dat): call fopen(C:\Program
Files\GRASS-65-SVN\proj\proj_def.dat) - succeeded
pj_open_lib(c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus):
Files\GRASS-65-SVN\proj\c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus) - failed
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>: while processing file: <stdin>, line 1
pj_transform(): Unknown error
this time it's the path name that's getting munched, or otherwise mangled.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:10>
