[GRASS-dev] Re: [GRASS-user] r.univar.zonal not installing
Hamish hamish_b at yahoo.com
Wed Oct 6 16:30:40 EDT 2010
Hamish wrote:
> for 6.5svn I would vote to add .zonal as another module if
> you like, but do not replace r.univar.
well, actually the diff is not so huge to make code auditing that
much of a problem, but it would need to be well tested.
generally I would prefer if we slow down new development in 6.5
in favour of 7 though, and we do that by not backporting major
architecture changes from trunk that do not fix major flaws in the
6.x architecture which can not be otherwise somehow worked around.
...ie just be more conservative with changes to 6.x now. otherwise
the stable branch never stabalizes and grass7 never gets worked
on...
thanks,
Hamish
