[GRASS-dev] Re: [GRASS GIS] #886: improve module wxGUI tab logic
trac at osgeo.org
Sat Oct 9 18:04:48 EDT 2010
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: tabs | Platform: All
Cpu: All |
Changes (by hamish):
* keywords: => tabs
Comment:
any more thoughts on this? ie some way to get around some of the wx module
gui usability problems when none of the module's options are (nor should
be) required, or some important non-required ones are hidden away in less
obvious tabs.
I fear for things like m.proj that default to input=stdin that the best
solution from the gui will ultimately be a wrapper script that forces it
to require a real file.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/886#comment:3>
