[GRASS-dev] Re: html error (access file not found) on compilation of i.landsat.toar in v7
Yann Chemin yann.chemin at gmail.com
Thu Oct 14 01:23:28 EDT 2010
Answering to it, it seems the error does not forbid the code to work
as a module but the manual section is not existing because of that
error.
http://trac.osgeo.org/grass/ticket/1068 mentions about the
access/LOCATION error part.
I should have a look at the html file again, maybe some formating has
changed from v6 to v7.
On 14 October 2010 14:46, Yann Chemin <yann.chemin at gmail.com> wrote:
> Hello,
> I have been able to compile all the i.landsat.toar C code so far in
> v7, but it does something strange with the html (old description.html
> renamed i.landsat.toar.html in v7).
> access: No such file or directory
> ERROR: LOCATION <<
>       /home/icwater/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation
>       >> not available
> make: *** [i.landsat.toar.tmp.html] Error 1
> rm i.landsat.toar.tmp.html
> What is the reason?
> Thank you,
> Yann
> Yann Chemin
> Senior Spatial Hydrologist
> www.csu.edu.au/research/icwater
> M +61-4-3740 7019
Yann Chemin
M +61-4-3740 7019
