[GRASS-dev] Re: GRASS-dev] grass fails to detect wxpython version
Massimo Di Stefano
massimodisasha at gmail.com
Fri Oct 15 01:47:12 EDT 2010
sorry, i haven't specified it in the previouse mail,
but i'm already using in my configure instruction :
--with-python=/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7-config \
--with-wxwidgets=/usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config
the problem seems to be in my "version number" and in "globalvar.py" :
GRASS 6.5.svn (<UNKNOWN>):~ > python
Python 2.7 (r27:82500, Jul 17 2010, 23:39:56)
[GCC 4.2.1 (Apple Inc. build 5664)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import wx
>>> ver = wx.version().split(' ')[0]
>>> ver
'2.9.1.1.b20101001'
>>> version = [2, 8, 11, 0]
>>> if map(int, ver.split('.')) < version:
... print 'false'
File "<stdin>", line 1, in <module>
ValueError: invalid literal for int() with base 10: 'b20101001'
>>> ver.split('.')
['2', '9', '1', '1', 'b20101001']
>>> ver.split('.')[-1]
'b20101001'
>>> ver.split('.')[-1:]
['b20101001']
>>> ver.split('.')[:-1]
['2', '9', '1', '1']
i'm looking to hack globalvar to fix the problem,
thanks for any hints.
Ciao,
Massimo.
Il giorno 15/ott/2010, alle ore 05.30, Michael Barton ha scritto:
> Because it is a custom Python build, you might need to specify --with-python=/System/Library/Frameworks/Python.framework/Versions/2.9/bin/python2.9-config
> (check to make sure this is where the file is and what it is called.)
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Oct 14, 2010, at 7:03 PM, <grass-dev-request at lists.osgeo.org> wrote:
>> Message: 8
>> Date: Fri, 15 Oct 2010 01:43:38 +0200
>> From: Massimo Di Stefano <massimodisasha at gmail.com>
>> Subject: [GRASS-dev] grass fails to detect wxpython version
>> To: grass-dev at lists.osgeo.org
>> Message-ID: <28CEF25E-7586-419C-AC9E-AF249331B0E2 at gmail.com>
>> Content-Type: text/plain; charset=us-ascii
>> Hi All,
>> for some reason i need to switch to python 2.7 on mac osx
>> i'm using a custom build python2.7 (i386 + x86_64)
>> it is my default python version.
>> epy:~ epy$ which python
>> I'm using a snapshot buld for wx python2.9 (build with cocoa for python2.7)
>> it is available there :
>> http://wxpython.wxcommunity.com/preview/20101001/
>> http://wxpython.wxcommunity.com/preview/20101001/wxPython2.9-osx-2.9.1.1.b20101001-cocoa-py2.7.dmg
>> tring to run wx-config, i have :
>> /usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config --version-full
>> 2.9.1.1
>> i'm building grass6_devel using as wx configure, this line :
>> the build ends without errors but tring to run grass i have :
>> GRASS 6.5.svn (<UNKNOWN>):~ > g.gui
>> Launching 'wxpython' GUI in the background, please wait ...
>> ERROR: wxGUI requires wxPython >= 2.8.1.1. Requested version of wxPython not found.
>> whay it tel me a version < 2.8 ?
>> my new wc-config is not in the path .. can be this the reason ? i suppose configure should handle the path i issued to the wxwidgets options.
>> have you any clue on what's wrong ?
>> thanks,
>> Massimo.
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
