[GRASS-dev] Re: GRASS-dev] grass fails to detect wxpython version
Michael Barton
Michael.Barton at asu.edu
Fri Oct 15 03:23:15 EDT 2010
OK. Keep us posted. I'm concerned that wxPython 2.9 is not backward compatible.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 14, 2010, at 11:22 PM, Massimo Di Stefano wrote:
I was to mutch optimist :-)
i bypassed the version problem, but obviously from 2.8.x and 2.9.x
there are some api changes ... so the gui doesn't work
i'lll try to work a bit on it to see what can i do.
this the first error i'm having running wxpython gui under wx-2.9 :
GRASS 6.5.svn (<UNKNOWN>):~ > g.gui
Launching 'wxpython' GUI in the background, please wait ...
File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1637, in <module>
sys.exit(main())
File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1630, in main
app = GMApp(workspaceFile)
File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1552, in __init__
wx.App.__init__(self, False)
File "/usr/local/lib/wxPython-2.9.1.1.b20101001/lib/python2.7/site-packages/wx-2.9.1-osx_cocoa/wx/_core.py", line 8470, in __init__
self._BootstrapApp()
File "/usr/local/lib/wxPython-2.9.1.1.b20101001/lib/python2.7/site-packages/wx-2.9.1-osx_cocoa/wx/_core.py", line 8035, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1573, in OnInit
workspace = self.workspaceFile)
File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 112, in __init__
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
File "/usr/local/lib/wxPython-2.9.1.1.b20101001/lib/python2.7/site-packages/wx-2.9.1-osx_cocoa/wx/_gdi.py", line 1265, in __init__
_gdi_.Icon_swiginit(self,_gdi_.new_Icon(*args, **kwargs))
wx._core.PyAssertionError: C++ assertion "err == noErr" failed at /BUILD/wxPython-src-2.9.1.1.b20101001/src/osx/core/bitmap.cpp(590) in GetIconRef(): Error when constructing icon ref
sorry, i haven't specified it in the previouse mail,
but i'm already using in my configure instruction :
--with-python=/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7-config \
--with-wxwidgets=/usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config
the problem seems to be in my "version number" and in "globalvar.py" :
GRASS 6.5.svn (<UNKNOWN>):~ > python
Python 2.7 (r27:82500, Jul 17 2010, 23:39:56)
[GCC 4.2.1 (Apple Inc. build 5664)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import wx
>>> ver = wx.version().split(' ')[0]
>>> ver
'2.9.1.1.b20101001'
>>> version = [2, 8, 11, 0]
>>> if map(int, ver.split('.')) < version:
... print 'false'
File "<stdin>", line 1, in <module>
ValueError: invalid literal for int() with base 10: 'b20101001'
>>> ver.split('.')
['2', '9', '1', '1', 'b20101001']
>>> ver.split('.')[-1]
'b20101001'
>>> ver.split('.')[-1:]
['b20101001']
>>> ver.split('.')[:-1]
['2', '9', '1', '1']
i'm looking to hack globalvar to fix the problem,
thanks for any hints.
Ciao,
Massimo.
Il giorno 15/ott/2010, alle ore 05.30, Michael Barton ha scritto:
Because it is a custom Python build, you might need to specify --with-python=/System/Library/Frameworks/Python.framework/Versions/2.9/bin/python2.9-config
(check to make sure this is where the file is and what it is called.)
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Oct 14, 2010, at 7:03 PM, <grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org>> wrote:
Message: 8
Date: Fri, 15 Oct 2010 01:43:38 +0200
From: Massimo Di Stefano <massimodisasha at gmail.com<mailto:massimodisasha at gmail.com>>
Subject: [GRASS-dev] grass fails to detect wxpython version
To: grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
Message-ID: <28CEF25E-7586-419C-AC9E-AF249331B0E2 at gmail.com<mailto:28CEF25E-7586-419C-AC9E-AF249331B0E2 at gmail.com>>
Content-Type: text/plain; charset=us-ascii
Hi All,
for some reason i need to switch to python 2.7 on mac osx
i'm using a custom build python2.7 (i386 + x86_64)
it is my default python version.
epy:~ epy$ which python
I'm using a snapshot buld for wx python2.9 (build with cocoa for python2.7)
it is available there :
http://wxpython.wxcommunity.com/preview/20101001/
http://wxpython.wxcommunity.com/preview/20101001/wxPython2.9-osx-2.9.1.1.b20101001-cocoa-py2.7.dmg
tring to run wx-config, i have :
/usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config --version-full
2.9.1.1
i'm building grass6_devel using as wx configure, this line :
the build ends without errors but tring to run grass i have :
ERROR: wxGUI requires wxPython >= 2.8.1.1. Requested version of wxPython not found.
whay it tel me a version < 2.8 ?
my new wc-config is not in the path .. can be this the reason ? i suppose configure should handle the path i issued to the wxwidgets options.
have you any clue on what's wrong ?
thanks,
Massimo.
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
