[GRASS-dev] Re: GRASS-dev] grass fails to detect wxpython version
Michael Barton
Michael.Barton at asu.edu
Fri Oct 15 11:18:48 EDT 2010
Massimo,
At the moment, I'm too tied up to be able to do much. But I did just install a new wxPython and noticed that you can get a binary for 2.8.10.11 that supports Python 2.7 now.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 15, 2010, at 1:07 AM, Massimo Di Stefano wrote:
> Hi,
> Michael, yes it is not backward compatible,
> i have commented out some lines in 4 different files in the gui source,
> globarcar.py (lines 41,42,61,62)
> wxgui.py (line 112)
> ghelp.py (line 103)
> mapdisp.py (line 132)
> now the gui start but is not usable due to the commented code.
> Generally i can see the code lines where we set an icon file, is no longer working on wx 2.9.
> On osx snow leopard the lack of cocoa support from wx 2.8 is a bad problem
> .. actually i'm using python2.7 (i386 + x86_64)
> and no wx 2.8 binay are avaiable ... so i had to stay on tcltk
> (or using a custom gui i'm working on, done in pyqt but is pretty immature yet)
> i tried the wx2.9 snapshot demos and it works pretty fine, seems 2.9 is near to be mature.
> i can give you my time offering support to build and test grass gui using wx2.9
> and providing logs and tentative of debug.... but unlucky i've not a good knowledge of wxgrass and wx itself.
> Please let me know if make sense for you and what do you think about.
> maybe is the case to switch this discussion to the gui mailing list?
> thanks a lot!
> Massimo.
> Il giorno 15/ott/2010, alle ore 09.23, Michael Barton ha scritto:
>> OK. Keep us posted. I'm concerned that wxPython 2.9 is not backward compatible.
>> Michael
