[GRASS-dev] running grass from python
Massimo Di Stefano
massimodisasha at gmail.com
Fri Oct 15 13:15:16 EDT 2010
Hello All,
i'm intersted to know if it is possible to use the grass functionalities directly from python
without the needs to run a grass session from bash.
i think the first thisk i have to do is to set my PYTHONPATH to where i have grass-python libs
then i have to set the grass environment vars (gisenv?)
have you any hints on how to do it (if possible) ?
thanks a lot,
Massimo.
