[GRASS-dev] bilinear and bicubic raster interpolation
Sun Oct 17 05:40:07 EDT 2010
Glynn Clements wrote:
> However, there is another issue with r.proj (7.0) and r.proj.seg
> (6.x): bilinear and cubic interpolation give a small number of garbage
> results due to incorrect use of the caching mechanism (blocks are
> being replaced while references remain). I'll fix this shortly.
This should be fixed by r43944.
