[GRASS-dev] Re: [GRASS-user] Error when importing data in Windows
with Python Script
Glynn Clements
glynn at gclements.plus.com
Wed Oct 20 11:29:54 EDT 2010
Luis Lisboa wrote:
> > > Ok at utils.py at line 21 I placed:
> > > import shlex
> > > and at the bottom of the file (linhe 424) I placed
> > > def split(s):
> > > return shlex.split(s, posix = (sys.platform != "win32"))
> > > And I still got this error. Did I did something wrong?
> > It isn't sufficient to add the function; you have to change (some of)
> > the existing shlex.split() calls to use utils.split() instead.
> SOrry to bother you and the rest of the people. But when you say that
> it'sn't enough, you mean that all shlex.split() shall be substituted
> by utils.split()? is that it?
Yes.
Well, not all of them, but the ones which relate to the command
prompt. Others, e.g. parsing of commands from menudata.xml, shouldn't
depend upon the platform.
