[GRASS-dev] Re: [GRASS GIS] #224: cache bug in DGLib
trac at osgeo.org
Sun Oct 24 06:46:59 EDT 2010
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Resolution: | Keywords: dglib, cache, v.net.path
Platform: All | Cpu: All
Comment(by mmetz):
Replying to [comment:16 huhabla]:
> I have tested v.net.path using a dataset with 460000 lines, one start
point and 100 end points. It works quite fast (<5min) and the result seems
to be correct. Screenshot is attached. IMHO back porting to 6.4.1 would be
greatly appreciated.
Thanks for testing!
Would it be asked too much to do the same test with the cache disabled and
compare results? I am aware that this might take some time, e.g. running
overnight.
Also, with cache enabled it would be great if you could design a test
where you recover a path to a given point and in the very next step
recover a path from the same starting point but the end point must be
exactly one line (edge) farther away from the previous end point. First,
this second end point must be reachable, second, the shortest path to this
second end point should go through the previous end point, unless there is
a shorter path avoiding the previous end point. I have done that with a
small test vector that should represent all sorts of special cases
targeting BUG1 and BUG2 but I might have overlooked something.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/224#comment:17>
