[GRASS-dev] g.region -g3
Patricio Toledo patricioantoniotoledo at gmail.com
Wed Oct 27 10:42:31 EDT 2010
Hi
I would like to ask about a change in g.region behaviour.
When -g3 option is used, g.region prints the number of cell in
three dimensions as 3dcells. Two comments, first it is
inconsisten with other 3d names, it should be called cells3.
Second is that if one uses eval $(g.region -g3) then the shell
complains as 3dcells is not a qualified variable name (i have
tested this on bash and zsh) as it starts with a number, again
cells3 fixes the problem.
I am using GRASS 6.4.0+42329 (debian sueeze).
Well, thats all
Thanks a lot
Patricio
