[GRASS-dev] Re: [GRASS GIS] #1203: explain command mapping to wxGUI
menus
trac at osgeo.org
Wed Oct 27 17:11:32 EDT 2010
#1203: explain command mapping to wxGUI menus
Reporter: timmie | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.1
Component: Website | Version: unspecified
Keywords: | Platform: All
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 timmie]:
> Replying to [comment:1 hellik]:
> > Replying to [ticket:1203 timmie]:
> > > Hello,
> > > there was nice PDF file created by Hamish that shows which grass
command (module) is mapped to which menu in the wxGUI.
> > Do you mean this one: GRASS 6.4.0 Command list?
> > http://grass.osgeo.org/gdp/grassmanuals/grass64_module_list.pdf
> Yes, I am referencing to that document.
> Please add it to the GRASS documentation.
> This is also linked to #645
> http://trac.osgeo.org/grass/ticket/645
> Using the GUI, I often find myself lost when trying to find certain
modules!
the linked pdf should be updated to the GRASS64-release of september 2010.
in the upcoming GRASS6.4.1 there are 3 improvements for finding modules in
the wxgui:
(1) there is the search-module-tab in the wxgui-layer manager (just as in
grass65)
(2) in the command console tab in the wxgui the search module engine can
be activated for a quick launch of a certain module
(3) in the command console tab you can type for example r.o and you jump
automagically to all raster output-commands (r.out.xxx) and can choose the
desired command
I'm starting the most time a module by option (3), it's a very fast way to
avoid searching a module in the wx-pulldown.menues.
HTH
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1203#comment:3>
