[GRASS-dev] Fwd: [GRASS-user] g.extension not working
Markus Neteler neteler at osgeo.org
Wed Sep 1 01:40:08 EDT 2010
---------- Forwarded message ----------
Date: Wed, 1 Sep 2010 07:39:26 +0200
Subject: Re: [GRASS-user] g.extension not working
To: Daniel Victoria <daniel.victoria at gmail.com>
Yes, that's the reason then (same here).
 We need to add a condition to skip the install ste in this case.
Markus
On 9/1/10, Daniel Victoria <daniel.victoria at gmail.com> wrote:
> I do have /usr/bin/install installed. I run Ubuntu and coreutils is
> the latest version.
> One small quirk though. I compiled Grass 6.5svn running make but I did
> not install it (make install). I'm running it straigh from the build
> directory (start script at ./bin.i686-pc-linux-gnu and binaries at
> ./dist.i686-pc-linux-gnu). Could that be related?
> Thanks
> Daniel
> On Tue, Aug 31, 2010 at 10:01 PM, Hamish <hamish_b at yahoo.com> wrote:
>> Daniel wrote:
>>> Ok, g.extension works and downloads svn addons
>> great! thanks for the confirmation.
>>> but r.stream.extract compilation fails.
>>> Bellow is the r.stream.order compilation log error.
>>> make[1]: Leaving directory
>> ok, so actually it built ok, but fails during installation:
>>> Installing r.stream.order...
>>> /usr/bin/install: cannot stat
>> aka the "install" program is not installed.
>> No idea what provides that on your linux distro, on Debian and Ubuntu
>> it comes in the "coreutils" package.
>> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
