[GRASS-dev] Re: [GRASS GIS] #1143: WinGrass64RC7 - db.execute
trac at osgeo.org
Thu Sep 2 15:53:28 EDT 2010
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 6.4.0
Component: Database | Version: 6.4.0 RCs
Resolution: fixed | Keywords: wingrass, db.execute
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:6 hellik]:
> Replying to [comment:4 hellik]:
> > Replying to [comment:3 martinl]:
> > > Replying to [comment:2 martinl]:
> > > > Replying to [ticket:1143 hellik]:
> > > > > in WinGRASS-6.4.0RC7-1-Setup.exe, db.execute is greyed out in
the wxgui-pulldown-menue Database -> Query -> SQL statement (=db.execute).
> > > > hopefully fixed in r43388.
> > > > > after typing db.execute in the wxgui-command-line, the whole
wxgui freezes.
> > > > seems to work on my PC.
> > > Could anyone confirm that the bug was fixed? The only one blocker
for 6.4.0... Thanks.
> > there seems to be no nightly build from last night
(http://josef.fsv.cvut.cz/wingrass/grass64/). so I have to compile for
myself first.
> > Helmut
> starting grass64 inside
> C:\OSGeo4W\usr\src\grass64svn\bin.i686-pc-mingw32
> db.execute isn't greyed out and db.execute also works from the wxgui-
commandline, there's no GUI-freezing.
> I'll build locally a WinGrass64-installer and try this also.
> Helmut
also tried with a self built WinGrass64-installer (r43388) - installed in
C:\Program Files\GRASS-64-SVN - all works fine now.
thanks for the fix.
I'll close the ticket.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1143#comment:7>
