[GRASS-dev] wxnviz broken in 6.5 on Linux 64bit
Martin Landa landa.martin at gmail.com
Mon Sep 6 05:22:51 EDT 2010
2010/8/30 Markus Neteler <neteler at osgeo.org>:
>> 2010/8/30 Markus Metz <markus.metz.giswork at googlemail.com>:
>>> Problem is ctypes, the Makefiles have been backported from trunk
>>> without adapting to the build system in 6.5.
>> right, see http://trac.osgeo.org/grass/ticket/1125#comment:43
> In the long run it might be better to backport the new Makefiles system
> from GRASS 7. It would also help for g.extension and the like.
I would vote for minimalistic approach, ctypes will be probably
backported to 6.4.x, any heavy changes are complicated in this regard.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
