[GRASS-dev] [GRASS GIS] #1151: v.extract: where letting all pass on
double prec
trac at osgeo.org
Wed Sep 8 04:15:11 EDT 2010
#1151: v.extract: where letting all pass on double prec
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: v.extract | Platform: Linux
Cpu: x86-64 |
I'm trying to clear out some vector points where the depth_m double prec
attribute column is set with null= 9999.9. so I try
v.extract in=nav_points out=nav_points_clean_depths \
where='depth_m < 9999'
but I still get all 129k points (confirmed by v.univar). `v.db.select
where= | wc -l` shows the correct (cleaned) number, so I could cleanse it
though v.db.select|v.in.ascii as a work-around.
A quick test with `v.random -z zmin= zmax=` with 1000 points seemed to
work fine.
the highest real point in it is around 2300, and even with < 500 many
fewer points are written but still some 9999.9s get through. ??! index off
by one error??
seen in 6.4.0 and 6.5svn, haven't tested in trunk.
data avail privately upon request.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1151>
