[GRASS-dev] r.sim.water at debug level 5
Hanlie Pretorius hanlie.pretorius at gmail.com
Wed Sep 8 05:52:19 EDT 2010
I've been posting about problems with r.sim.water. I have compiled
GRASS64 SVN with debugging symbols and set the GRASS DEBUG environment
variable to level 5. I'm also running GRASS from gdb.
I ran r.sim.water on a region with 1103886544 cells and it bombed out
quickly. The output was:
GRASS 6.4.0svn (c83a_tm_29deg_e):~ > r.sim.water --overwrite
elevin=c83a_dem_25m at PERMANENT
dxin=c83a_dem_25m_clipped_dx at rsimwater_toetse
dyin=c83a_dem_25m_clipped_dy at rsimwater_toetse
rain=rain_50 at rsimwater_toetse infil=infilt_0 at rsimwater_toetse
manin=manning_0.05 at rsimwater_toetse
depth=depth_1mres_rain50_infil0_niter10 at rsimwater_toetse
disch=disch_1mres_rain50_infil0_niter10 at rsimwater_toetse
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj:       99
D3/5: region item: zone:       0
D3/5: region item: north:      -3122229.69982072
D3/5: region item: south:      -3155672.30728643
D3/5: region item: east:       -33474.90929218
D3/5: region item: west:       -66483.27873573
D3/5: region item: cols:       33008
D3/5: region item: rows:       33443
D3/5: region item: e-w resol:  1.00001119
D3/5: region item: n-s resol:  0.99998826
D3/5: region item: top:        0.5
D3/5: region item: bottom:     -0.5
D3/5: region item: cols3:      33008
D3/5: region item: rows3:      33443
D3/5: region item: depths:     1
D3/5: region item: e-w resol3: 1.00001119
D3/5: region item: n-s resol3: 0.99998826
D3/5: region item: t-b resol:  1
D3/5: rain_val is set to: -999.990000
D3/5: manin_val is set to: -999.990000
D3/5: infil_val is set to: -999.990000
default nwalk=-2087194208, rwalk=2207773088.000000
Killed
Since GRASS itself doesn't exit abnormally, gdb doesn't seem to notice
that anything is wrong.
Is there anywhere else (a log file perhaps) where I can try and find
out what is going on?
Thanks
Hanlie
