[GRASS-dev] r.sim.water at debug level 5
Hanlie Pretorius
hanlie.pretorius at gmail.com
Wed Sep 8 08:03:28 EDT 2010
Thanks for the reply, Soeren.
I have had similar results on rasters with fewer than 1 million cells.
The process runs for a litte longer but then also gets killed.
I made the resolution very fine on purpose because I was trying to
crash r.sim.water to get to the debugging messages. Does that make
sense?
2010/9/8, Soeren Gebbert <soerengebbert at googlemail.com>:
> Hello,
> IMHO your region resolution is much to large for r.sim.water:
> 33008x33443 cells -> 1.1 billion cells.
> You can use a coarse resolution or you can split your dataset in
> smaller pieces for computation.
> r.sim.water loads all raster maps into your memory and creates
> additionally a maximum of 7000000 walkers. I would suggest to use
> about 1000000 cells for computation.
> Best
> Soeren
> 2010/9/8 Hanlie Pretorius <hanlie.pretorius at gmail.com>:
>> Hi,
>> I've been posting about problems with r.sim.water. I have compiled
>> GRASS64 SVN with debugging symbols and set the GRASS DEBUG environment
>> variable to level 5. I'm also running GRASS from gdb.
>> I ran r.sim.water on a region with 1103886544 cells and it bombed out
>> quickly. The output was:
>> GRASS 6.4.0svn (c83a_tm_29deg_e):~ > r.sim.water --overwrite
>> elevin=c83a_dem_25m at PERMANENT
>> dxin=c83a_dem_25m_clipped_dx at rsimwater_toetse
>> dyin=c83a_dem_25m_clipped_dy at rsimwater_toetse
>> rain=rain_50 at rsimwater_toetse infil=infilt_0 at rsimwater_toetse
>> manin=manning_0.05 at rsimwater_toetse
>> depth=depth_1mres_rain50_infil0_niter10 at rsimwater_toetse
>> disch=disch_1mres_rain50_infil0_niter10 at rsimwater_toetse
>> D2/5: G__read_Cell_head
>> D2/5: G__read_Cell_head_array
>> D3/5: region item: proj: 99
>> D3/5: region item: zone: 0
>> D3/5: region item: north: -3122229.69982072
>> D3/5: region item: south: -3155672.30728643
>> D3/5: region item: east: -33474.90929218
>> D3/5: region item: west: -66483.27873573
>> D3/5: region item: cols: 33008
>> D3/5: region item: rows: 33443
>> D3/5: region item: e-w resol: 1.00001119
>> D3/5: region item: n-s resol: 0.99998826
>> D3/5: region item: top: 0.5
>> D3/5: region item: bottom: -0.5
>> D3/5: region item: cols3: 33008
>> D3/5: region item: rows3: 33443
>> D3/5: region item: depths: 1
>> D3/5: region item: e-w resol3: 1.00001119
>> D3/5: region item: n-s resol3: 0.99998826
>> D3/5: region item: t-b resol: 1
>> D3/5: rain_val is set to: -999.990000
>> D3/5: manin_val is set to: -999.990000
>> D3/5: infil_val is set to: -999.990000
>> default nwalk=-2087194208, rwalk=2207773088.000000
>> Killed
>> Since GRASS itself doesn't exit abnormally, gdb doesn't seem to notice
>> that anything is wrong.
>> Is there anywhere else (a log file perhaps) where I can try and find
>> out what is going on?
>> Thanks
>> Hanlie
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
