[GRASS-dev] [GRASS GIS] #1152: d.out.file + cairo: errors writing
the image
trac at osgeo.org
Thu Sep 9 05:22:46 EDT 2010
#1152: d.out.file + cairo: errors writing the image
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Display | Version: unspecified
Keywords: d,out.file, cairo | Platform: Linux
Cpu: x86-64 |
in 6.4/6.5svn d.out.file with -c for the Cairo driver is having problems
writing to the file. ISTR this was discussed on the ML recently, with the
explanation something like that `d.mon start=` returns without waiting?
G65> d.out.file -c landsat
Saving display from Monitor: [x0] to <landsat.png>.
Image size [1115 x 988]
100%
ERROR: Cairo_draw_bitmap: Failed to create source
WARNING: Socket is already in use or not accepting connections.
WARNING: Use d.mon to select a monitor
ERROR: No graphics device selected
WARNING: Error - Monitor 'cairo' was not running
Screen export complete. (writing the file may take a small amount of time)
Image crop [1115 x 987]
Done.
the image is a large (7000x8000) raster with a d.grid and d.text
decorations over the top of it. I tried pushing in a `sleep 1` before each
d.* command from d.save, but no luck.
on a simple low-res image it does fine, as does running with the regular
PNG driver. same behavior on multiple machines & different linux distros.
(deb/ubu)
perhaps the solution is setting one of the display driver direct rendering
enviro variables?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1152>
