[GRASS-dev] Re: [GRASS GIS] #745: r.report formatting doesn't seem
 to be multi-byte aware
    trac at osgeo.org
    Thu Sep  9 20:03:56 EDT 2010
#745: r.report formatting doesn't seem to be multi-byte aware
 Reporter:  peifer       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  6.4.1
Component:  Raster       |     Version:  6.4.0 RCs
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [ticket:745 peifer]:
 The same issue applies to anything which attempts to format output
 containing user-supplied text (hard-coded text should all be ASCII).
 The main problem with fixing this is that the necessary functions aren't
 available on all systems, so we will need either wrapper functions or a
 lot of #ifdef's.
 An outline approach is to convert the string from multi-byte to wide with
 mbstowcs() or mbsrtowcs(), then either use wcslen() to find the number of
 characters in the wide string, or use wcswidth() to find the width (in
 columns) of the wide string.
 wcswidth() correctly handles the "full-width" characters found in CJK
 locales, which occupy two columns. However, wcswidth() is POSIX while
 wcslen() is C99. None of the necessary functions are in C89.
 Also, this rules out relying upon printf() etc for formatting, as printf's
 width specifiers are in "char"s (i.e. bytes), not characters or columns.
 BTW, regarding gawk/mawk: as the ticket notes, POSIX explicitly states
 that awk matches the behaviour of printf, i.e. field widths are in bytes,
 not characters/columns.
Ticket URL: <https://trac.osgeo.org/grass/ticket/745#comment:3>
