[GRASS-dev] Re: [GRASS GIS] #991: v.out.gpsbabel export fails with
layer=2
trac at osgeo.org
Fri Sep 10 12:03:50 EDT 2010
#991: v.out.gpsbabel export fails with layer=2
Reporter: needelsd | Owner: hamish
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: fixed | Keywords: GPS GPX export, v.out.gpsbabel, m.proj
Platform: MacOSX | Cpu: Unspecified
Changes (by donxfive):
* cc: donxfive (added)
Comment:
I still get "Error reading categories" with vectors that have layers other
than 1.
I'm using GRASS version 6.4.0svn on my Ubuntu laptop (w/ GNU sed version
4.1.5), and I fixed the problem by replacing
sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1 /# 1 /'
with
sed -r -e 's/^[PLBCFKA]/#&/' -e 's/^ [1-9]+ /#&/'
on line 253 of the
[http://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/scripts/v.out.gpsbabel/v.out.gpsbabel
v.out.gpsbabel script]. (The problem sed command is also used in
v.out.gpsbabel for 6.5-svn, and in v.out.gps for 7.0-svn.)
I've had no problems since I did this, but I'm not sure if it would work
for everyone.
Ticket URL: <http://trac.osgeo.org/grass/ticket/991#comment:8>
