[GRASS-dev] Re: [GRASS GIS] #763: r.statistics method=distribution:
no percentages for negative basemap values
trac at osgeo.org
Sat Sep 11 00:54:56 EDT 2010
#763: r.statistics method=distribution: no percentages for negative basemap
values
Reporter: peifer | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: r.statistics | Platform: Unspecified
Cpu: x86-32 |
Changes (by hamish):
* keywords: => r.statistics
Comment:
Replying to [comment:4 glynn]:
> Prior to 5.x, category zero was often used as a no-data value.
> 5.x added support for a distinguished null value (as well as
> floating-point), but some code still follows the old zero-is-null
> convention.
> Given the large number of occurrences of G_get_map_row[_nomask]()
> in 6.4, I can't help wondering whether all of the modules which
> were converted to use Rast_get_c_row() in 7.0 were actually
> converted correctly, or whether the function call was changed
> without any effort made to handle nulls.
as a test point, r.surf.contour in 6.4 still treats 0 as NULL (and is not
FP-aware), so if there are problems in the transition, they'll probably
show up there.
Ticket URL: <https://trac.osgeo.org/grass/ticket/763#comment:5>
