[GRASS-dev] [GRASS GIS] #1154: r.drain hangs using an r.walk surface
trac at osgeo.org
Sun Sep 12 13:41:28 EDT 2010
Reporter: abevan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.drain | Platform: MacOSX
Cpu: OSX/Intel |
GRASS 7.0.svn (spearfish):~ > r.walk -k -n elevation=elevation.10m
friction=elevation.10m coordinate=603289,4925264 output=anisoA
outdir=anisoAdir lambda=0
[[BR]]
Walking costs are a=0.720000 b=6.000000 c=1.999800 d=-1.999800
Lambda is 0.000000
Slope_factor is -0.212500
Will need at least 9.23 MB of disk space
Will need at least 12.29 MB of memory
Reading raster maps <elevation.10m at PERMANENT> and
<elevation.10m at PERMANENT>, initializing output...
100%
Initializing directional output
100%
Finding cost path
100%
Writing output raster map anisoA...
100%
Writing movement direction file anisoAdir...
100%
r.walk complete. Peak cost value: 18025.341210.
[[BR]]
GRASS 7.0.svn (spearfish):~ > r.drain -c -d input=anisoA indir=anisoAdir
output=fromAtoB coordinate=595080,4918109 --v
[[BR]]
Directional drain selected... checking for direction raster
direction read: 67.500000, neighbour found: 675
direction read: 22.500000, neighbour found: 225
direction read: 90.000000, neighbour found: 900
direction read: 0.000000, neighbour found: 0
direction read: 180.000000, neighbour found: 1800
Ticket URL: <https://trac.osgeo.org/grass/ticket/1154>
