[GRASS-dev] [GRASS GIS] #1157: WinGrass-Installer should include a
working gdal-version which is built against
trac at osgeo.org
Mon Sep 13 18:30:34 EDT 2010
#1157: WinGrass-Installer should include a working gdal-version which is built
against
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Packaging | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: All |
from the user-ML
http://lists.osgeo.org/pipermail/grass-user/2010-September/057851.html
>>Dear all,
>>I have just installed Wingrass7 from
>>[http://josef.fsv.cvut.cz/wingrass/grass70/]
>>When it is started the locations which work well with Grass6.4 version,
>>there is the error: Unable to get current geographic extent. Force
>>quitting wxGUI. Please run manual g.region to fix
>>problem....Importerror: No module named agw.customtreectrl
>>Or when I make new location by Location wizard there is the error: ..
>>[Error 2] No such file or directory: 'C:\\Program Files\\
>>GRASS-70-SVN\\etc\\proj-parms.table'
>>Please help me what should I do?
>>Thank you
>>Thy
>I can confirm this.
>at the moment the nightly WinGrass7-builds are built against gdal17 from
osgeo4w,
>which is in a preliminary status at the moment.
>I build from time to time WinGrass7 for my own with gdal16 from osgeo4w
and there are
>no such error messages.
>best regards
>Helmut
it seems to be a mixing of different gdal-versions.
WinGrass70 is built against gdal17. but in WinGrass7 (installed by the
installer) there is
only gdal15 in the path and available in the WinGrass7-command-line, but
no gdal17.
AFAIK there are some important changes from gdal15 to gdal17. so a
WinGrass7 built against gdal17
isn't working with gdal15 in the path?
so maybe the WinGrass7-installer built against gdal17 should be adapted in
that way to adopt gdal17 as the regular version
of gdal?
best regards
Helmut
related to the nightly WinGrass-builds, all branches and the recommended
way of compiling wingrass in the wiki (both inside the osgeo4w-stack).
at the moment WinGrass64 and WinGrass65 are built against gdal16,
WinGrass70 against gdal17. but in the WinGrassXX-installer only gdal15 is
available in the path, but no gdal16/gdal17 and all dependecies
(GDAL_DATA, GDAL_DRIVER_PATH,
PYTHONPATH=%OSGEO4W_ROOT%\apps\gdal-16\pymod,
PATH=%OSGEO4W_ROOT%\apps\gdal-16\bin; the same for gdal17; see gdal16.bat
or gdal17.bat in C:\OSGeo4W\bin) living in C:\OSGeo4W\apps\gdal-16 or
C:\OSGeo4W\apps\gdal-17 are included.
the wingrass-installer should include a working gdal-version which the
WinGrass-version is installed against.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1157>
