[GRASS-dev] Re: [GRASS GIS] #1158: g.mremove fails when used with
wildcard in WinGRASS-6.4.0-1
trac at osgeo.org
Tue Sep 14 17:23:48 EDT 2010
#1158: g.mremove fails when used with wildcard in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: g.mremove, wildcards | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 hellik]:
> Replying to [ticket:1158 lponti]:
> > wxgui g.mremove called on vector with * wildcard does not work:
> I can confirm this (WinVista23-box).
> but it's very interesting:
> a first run of
> g.mremove -f vect=map*
> gets following
> Unable to delete file
'C:\cygwin\home\andy/latlong/luigi/vector/mapBloomday_Olive_11set10_Avg/hist'
> there seems to be a problem with the hist-section of the Grass-vector-
data-structure.
> but in a second run of
> all vector maps marked by the *-wildcard are deleted.
> Helmut
tested also with the latest wingrass65-nightly build. there also you need
two runs of g.mremove -f to remove a vector map.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1158#comment:2>
