[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii fails with long text file in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Wed Sep 15 04:31:56 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by lponti):
 Replying to [comment:2 hamish]:
 > [...] I think it is good to explicitly give x= and y=..
 Right, I forgot that. For sake of completeness, it does not help in this
 case:
 v.in.ascii input=Bloomday_Olive_11set10_Avg output=test_US_import fs=tab
 x=1 y=2 z=0
 Scanning input for column types...
 Maximum input row length: 31
 Maximum number of columns: 3
 Minimum number of columns: 3
 Column: 1  type: double
 Column: 2  type: double
 Column: 3  type: double
 Importando punti ...
 Populating table...
 ERROR: Could not close attribute table. The DBMI driver did not accept all
 attributes
 Neither does specifying column type:
 x=1 y=2 z=0 columns='x double, y double, value varchar(20)'
 Column number 3 <value> defined as string has double values
 Populating table...
 attributes
 Same with third column as double:
 x=1 y=2 z=0 columns='x double, y double, value double'
 Populating table...
 attributes
 > does it work if you switch to the SQLite DB backend?
 db.connect driver=sqlite
 database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
 db.connect -p
 driver:sqlite
 database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
 schema:
 group:
 This does not work:
 x=1 y=2 z=0
 Populating table...
 attributes
 nor does this:
 x=1 y=2 z=0 columns=x double, y double, value varchar(20)
 Populating table...
 attributes
 or this:
 x=1 y=2 z=0 columns=x double, y double, value double
 Populating table...
 attributes
 Note: the --overwrite flag does not work because of Ticket #1158, so after
 each v.in.ascii one needs to run g.remove twice on output file.
 > what if you add "columns='x double, y double, value varchar(20)'" ?
 See above.
 > or "-z z=3" ? (but no columns= to avoid creating a table at all)
 This works in sqlite (but no table, as you said):
 x=1 y=2 -z z=3
 Building topology for vector map <test_US_import>...
 Registering primitives...
    10001157 primitives registered
 1157 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 1156
 Number of primitives: 1157
 Number of points: 1157
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 v.in.ascii completo.
 (Wed Sep 15 10:19:46 2010) Command finished (0 sec)
 and with dbf (surprisingly the --overwrite flag works):
 v.in.ascii --overwrite input=Bloomday_Olive_11set10_Avg
 output=test_US_import fs=tab x=1 y=2 -z z=3
 Vector map <test_US_import> already exists and will be overwritten
 Building areas...
 0 areas built
 0 isles built
 Number of lines: 0
 Number of areas: 0
 Number of isles: 0
 Sounds like the table is the problem?
 Regards,
 Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:3>
