[GRASS-dev] [GRASS GIS] #1165: wingrass: cs2cs fails from the msys command line
GRASS GIS trac at osgeo.org
Sun Sep 19 03:47:37 EDT 2010
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.1
Component:  Projections/Datums  |     Version:  svn-develbranch6
 Keywords:  cs2cs, wingrass     |    Platform:  MSWindows XP
      Cpu:  x86-64              |
 while testing r.in.wms in 6.5svn in WinGrass I'm finding that a simple
 cs2cs call fails on the Msys command line. (actually happens in r.tileset)
 perhaps it's not finding the "/usr/share/proj/" support files (however
 that's registered in the Windows build), although `cs2cs -ld` et al. seem
 to work ok.
 GRASS 6.5> cs2cs +proj=longlat +to +proj=longlat
 Using from definition: proj=longlat
 Rel. 4.7.1, 23 September 2009
 <cs2cs.exe>:
 projection initialization failure
 cause: Unknown error
 program abnormally terminated
 GRASS 6.5> echo $?
 3
 the above ''should'' result in a blank line awaiting coord input.
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165>
