[GRASS-dev] [GRASS GIS] #1166: r.tileset: projection string
munching on wingrass
trac at osgeo.org
Sun Sep 19 04:01:05 EDT 2010
#1166: r.tileset: projection string munching on wingrass
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: r.tileset, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
while running r.in.wms at the MSys prompt on WinGrass with the NASA
OnEarth Landsat man page example, the r.tileset part does some weird
things to the +proj4 strings.
to see them, you need to add some debug messages to the r.tileset script,
line ~233:
g.message -i message="[$p_source_proj]"
g.message -i message="[$p_dest_proj]"
also I changed "message 3 ... $CS2CS" just above that to "g.message -i
message=..." so the cs2cs command line would show up.
the weirdness displayed by that g.message is:
echo "589980.0 4913700.0" | cs2cs -f "\.8\f" '+proj=utm' '+zone=13'
'+a=6378206.4' '+rf=294.9786982' '+no_defs'
'+nadgrids=c;C:\PROGRA~1\GRASS-~1\msys\Program
Files\GRASS-65-SVN\etc\nad\conus' '+to_meter=1.0' +to +init=epsg;4326
namely "+nadgrids=c;C:\PROGRA~1\..." starting with "c;" and
"+init=epsg:4326" becoming "+init=epsg;4326" (with an ';' instead of a
`g.proj -j` by itself looks fine.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1166>
