[GRASS-dev] Re: [GRASS GIS] #1163: wx wms import tool error
trac at osgeo.org
Sun Sep 19 07:46:22 EDT 2010
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: svn-develbranch6
Keywords: wms | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hamish):
> Replying to hellik:
> > AFAICT wget seems to be missing in the nightly WinGrass-build-
environment.
> and the same seems to be with libxml2.dll
that should be ok, you can ignore those. it automatically swaps over to
curl if wget isn't there, and it automatically swaps over to our own
parsing if xml2.exe isn't there. the only reason you see those messages is
because "which" on Windows is more noisy than in Gnu/Linux.
if you think the "which: {wget|xml2}: unknown command" messages are a big
problem we can probably send them to /dev/null.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1163#comment:6>
