[GRASS-dev] Re: [GRASS GIS] #1165: wingrass: cs2cs fails from the msys command line
GRASS GIS trac at osgeo.org
Sun Sep 19 20:16:49 EDT 2010
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.1
Component:  Projections/Datums  |     Version:  svn-develbranch6
 Keywords:  cs2cs, wingrass     |    Platform:  MSWindows XP
      Cpu:  x86-64              |
Comment(by hamish):
 Even after applying Helmut's GDAL_DATA path fix (r43520) to the
 destination files by hand, this still fails for me in 6.5svn on XP in the
 same way, both Msys (etc/Init.sh) and DOS-box (grass65svn.bat).
 I don't think it will help here, but should that "set GDAL_DATA=" also be
 added to mswindows/osgeo4w/ini.bat.tmpl as well?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:2>
