[GRASS-dev] [GRASS GIS] #1167: wx location wizard: proj4 terms fall off edge of window
GRASS GIS trac at osgeo.org
Mon Sep 20 03:03:34 EDT 2010
 Reporter:  hamish               |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  minor                |   Milestone:  6.4.1
Component:  Startup              |     Version:  svn-develbranch6
 Keywords:  wx, location wizard  |    Platform:  Linux
      Cpu:  x86-64               |
 in the wxGUI startup screen location wizard, if you define custom
 projection from PROJ4 terms (just cut&paste something out of the epsg
 file), once you get to the Summary page the Projection: line just
 continues off the right side of the window. Some sort of linewrap is
 needed I guess.
 (seen on ubuntu 10.04 + grass65)
 cheers,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1167>
