[GRASS-dev] Re: [GRASS GIS] #1164: newlines in sed scripts not portable for wingrass
GRASS GIS trac at osgeo.org
Mon Sep 20 15:48:02 EDT 2010
 Reporter:  hamish         |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  minor          |   Milestone:  6.4.1
Component:  Default        |     Version:  svn-develbranch6
 Keywords:  wingrass, sed  |    Platform:  MSWindows XP
      Cpu:  x86-64         |
Comment(by glynn):
 Replying to [ticket:1164 hamish]:
 > this is not portable for wingrass:
 echo "abc" | sed -e 's|b|\n|'
 > on linux you get the newline:
 > but in WinGrass you just get a quoted "n":
 It shouldn't work on Linux either; the documentation makes no mention of
 "\n" in the replacement. If you want to insert a literal newline, you're
 supposed to use backslash-newline, i.e.:
 which works on both Windows and Linux, and should work according to
 [http://www.opengroup.org/onlinepubs/9699919799/utilities/sed.html POSIX].
Ticket URL: <http://trac.osgeo.org/grass/ticket/1164#comment:1>
