[GRASS-dev] Re: [GRASS GIS] #1165: wingrass: cs2cs fails from the
msys command line
trac at osgeo.org
Mon Sep 20 16:53:10 EDT 2010
#1165: wingrass: cs2cs fails from the msys command line
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Projections/Datums | Version: svn-develbranch6
Keywords: cs2cs, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hellik):
this should be edited as:
(1) open OSGeo4W Shell (which is a windows-command-line with all osgeo4w-
utilities):
C:\>echo %PROJ_LIB%
C:\OSGeo4W\share\proj
C:\>cs2cs +proj=latlong +datum=WGS84 +to +proj=latlong +datum=WGS84
+pm=madrid
> 0 0
3d41'16.58"E 0dN 0.000
all works fine, '''but'''
(2) open osgeo4w-msys-shell
syringia at NADA ~
>$ echo $PROJ_LIB
syringia at NADA ~
> $ cs2cs +proj=latlong +datum=WGS84 +to +proj=latlong +datum=WGS84
+pm=madrid
0 0
nothing happens, no computations of the new coordinates, a blank line is
waiting (I've waited about 10 minutes, but nothing happend)
so maybe there are underlying problems of proj4/cs2cs in an (osgeo4w-
inherited) msys-environment?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:6>
