[GRASS-dev] Re: [GRASS GIS] #1165: wingrass: cs2cs fails from the
msys command line
trac at osgeo.org
Mon Sep 20 23:10:45 EDT 2010
#1165: wingrass: cs2cs fails from the msys command line
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Projections/Datums | Version: svn-develbranch6
Keywords: cs2cs, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hamish):
yes, setting PROJ_LIB in the startup scripts helps get cs2cs running. I
get stuck in stdin-land when running from the MSys-rxvt window just like
you, but `'echo "10 10" | cs2cs'` style works ok, so scripts should be ok
as well and that only an annoyance. (I would say these things confirm our
move away from msys's rxvt, but are not so strong to force us to take
drastic action to abandon it for 6.x just yet)
From the DOS box do you have to do F6, ^Z or so to break out of cs2cs? (I
didn't test that yet)
I assume your GDAL_DATA fix is good as well for end-user systems without
C:\OSGeo4W existing, but I haven't tested.
FWIW, there is also $GISBASE/etc/nad/, but I think we need the full set of
PROJ_LIB files that were present with it when proj4 was built. The
duplication shouldn't be more than a few megabytes.
thanks for the detective work,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1165#comment:8>
