[GRASS-dev] Re: [GRASS GIS] #1169: wget misses libssl32.dll
(affects r.in.wms)
trac at osgeo.org
Tue Sep 21 02:08:21 EDT 2010
#1169: wget misses libssl32.dll (affects r.in.wms)
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Packaging | Version: 6.4.0
Keywords: wget | Platform: MSWindows XP
Cpu: x86-32 |
Changes (by hamish):
* keywords: => wget
Comment:
Since `curl` is provided, and I assume is working, wget is not needed for
r.in.wms nor by anything else. The message from r.in.wms that it isn't
found is just an artifact of msys's `'which'` and can be ignored.
It is handy and if it's included* it might as well work, but it isn't
required for any module.
[*] Actually in the 6.5svn nightly build wget isn't in C:\Program
Files\GRASS-65-SVN\extrabin, so I question if it is actually installed by
us at all. Instead I guess it has been installed independently by the end-
user, so not a problem of our causing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1169#comment:2>
