[GRASS-dev] [GRASS GIS] #1170: r.in.gdal and r.external: take
vertical datum if available
trac at osgeo.org
Tue Sep 21 03:22:49 EDT 2010
#1170: r.in.gdal and r.external: take vertical datum if available
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Projections/Datums | Version: svn-trunk
Keywords: vdatum, r.in.gdal, r.external | Platform: All
Cpu: All |
Frank W is in the process of adding better vertical datum support to
$everything in the support libs.
http://lists.osgeo.org/pipermail/liblas-devel/2010-September/000976.html
It would be good to feed that info, if avail, to { G_write_raster_vdatum()
| Rast_write_vdatum() }.
Also I am not sure about the status of vertical datum metadata in the
vector engine, but we could start to think about that as well.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1170>
