[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii points import fails in
WinGRASS-6.4.0-1
trac at osgeo.org
Tue Sep 21 17:56:36 EDT 2010
#1159: v.in.ascii points import fails in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: v.in.ascii | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:15 lponti]:
> Applied Glynn's patch [...], compiled [...], and it works for the
> your simple test
> The point can be displayed, and the dbf table seems ok.
> Also works using a longer sample text file I previously linked
great. will port to other branches ASAP
> Still not entirely clear to me which variable I am supposed to
> set in order to get full English messages.
perhaps:
GRASS> LANG=C v.in.ascii ...
? (anyway the idea is to have it be understandable to as many people as
possible & be able to grep the code for the exact message text; if it's
only 98% english it's not a problem if those other conditions are met)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1159#comment:16>
