[GRASS-dev] Re: [GRASS GIS] #1165: wingrass: cs2cs fails from the msys command line
GRASS GIS trac at osgeo.org
Wed Sep 22 05:00:33 EDT 2010
  Reporter:  hamish              |       Owner:  grass-dev@…
      Type:  defect              |      Status:  closed
  Priority:  normal              |   Milestone:  6.4.1
 Component:  Projections/Datums  |     Version:  svn-develbranch6
Resolution:  fixed               |    Keywords:  cs2cs, wingrass
  Platform:  MSWindows XP        |         Cpu:  x86-64
Changes (by hamish):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I don't consider cs2cs in msys not releasing stdin to be a major bug, or
 at least one we can do much about, so closing the report as the main
 problem is now solved and committed.
 thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/1165#comment:11>
