[GRASS-dev] Re: [GRASS GIS] #1171: wingrass: include a gpsbabel with XML support
GRASS GIS trac at osgeo.org
Wed Sep 22 16:15:36 EDT 2010
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  enhancement         |      Status:  new
 Priority:  normal              |   Milestone:  6.4.1
Component:  Packaging           |     Version:  svn-develbranch6
 Keywords:  gpsbabel, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-64              |
Comment(by hellik):
 Replying to [comment:4 hellik]:
 > Replying to [comment:3 hamish]:
 > > see libexpat.dll discussion in:
 > >  https://trac.osgeo.org/osgeo4w/ticket/59
 > >  https://trac.osgeo.org/osgeo4w/ticket/171
 > > > "there is already a copy of that in osgeo4w/bin/"
 > > if so, can we copy it over to GRASS-64-SVN/extralib/ ?
 > > or is the error message accurate and it needs to be found at build-
 time to work?
 > > Hamish
 > just a little test:
 > - I've re-installed gpsbabel by the osgeo4w-setup/installer
 > - gpsbabel.exe lives in c:\osgeo4w/bin with following properties:
 > C:\wd\mg>gpsbabel --version
 > GPSBabel Version 1.4.1.  http://www.gpsbabel.org
 > 20.07.2010  20:29           845.824 GPSBabel.exe
 > Usage:
 >     gpsbabel [options] -i INTYPE -f INFILE [filter] -o OUTTYPE -F
 OUTFILE
 >     gpsbabel [options] -i INTYPE -o OUTTYPE INFILE [filter] OUTFILE
 >     Converts GPS route and waypoint data from one format type to
 another.
 >     The input type and filename are specified with the -i INTYPE
 >     and -f INFILE options. The output type and filename are specified
 >     with the -o OUTTYPE and -F OUTFILE options.
 >     If '-' is used for INFILE or OUTFILE, stdin or stdout will be used.
 >     In the second form of the command, INFILE and OUTFILE are the
 >     first and second positional (non-option) arguments.
 >     INTYPE and OUTTYPE must be one of the supported file types and
 >     may include options valid for that file type.  For example:
 >       'gpx', 'gpx,snlen=10' and 'ozi,snlen=10,snwhite=1'
 >     (without the quotes) are all valid file type specifications.
 > Options:
 >     -p               Preferences file (gpsbabel.ini)
 >     -s               Synthesize shortnames
 >     -r               Process route information
 >     -t               Process track information
 >     -T               Process realtime tracking information
 >     -w               Process waypoint information [default]
 >     -b               Process command file (batch mode)
 >     -c               Character set for next operation
 >     -N               No smart icons on output
 >     -x filtername    Invoke filter (placed between inputs and output)
 >     -D level         Set debug level [0]
 >     -l               Print GPSBabel builtin character sets and exit
 >     -h, -?           Print detailed help and exit
 >     -V               Print GPSBabel version and exit
 > File Types (-i and -o options):
 >       gdb                   Garmin MapSource - gdb
 >         cat                   Default category on output (1..16)
 >         bitscategory          Bitmap of categories
 >         ver                   Version of gdb file to generate (1..3)
 >         via                   (0/1) Drop route points that do not have
 an equivalent w
 >         roadbook              (0/1) Include major turn points (with
 description) from
 >       mapsource             Garmin MapSource - mps
 >         snlen                 Length of generated shortnames
 >         snwhite               (0/1) Allow whitespace synth. shortnames
 >         mpsverout             Version of mapsource file to generate
 (3,4,5)
 >         mpsmergeout           (0/1) Merge output with existing file
 >         mpsusedepth           (0/1) Use depth values on output (default
 is ignore)
 >         mpsuseprox            (0/1) Use proximity values on output
 (default is ignore)
 >       pcx                   Garmin PCX5
 >         deficon               Default icon name
 >         cartoexploreur        (0/1) Write tracks compatible with Carto
 Exploreur
 >       garmin                Garmin serial/USB protocol
 >         get_posn              (0/1) Return current position as a
 waypoint
 >         power_off             (0/1) Command unit to power itself down
 >         resettime             (0/1) Sync GPS time to computer time
 >         category              Category number to use for written
 waypoints
 >       gtrnctr               Garmin Training Center
 >         course                (0/1) Write course rather than history,
 default yes
 >         sport                 Sport: Biking (deflt), Running,
 MultiSport, Other
 >       geo                   Geocaching.com .loc
 >         nuke_placer           (0/1) Omit Placer name
 >       kml                   Google Earth (Keyhole) Markup Language
 >         lines                 (0/1) Export linestrings for tracks and
 routes
 >         points                (0/1) Export placemarks for tracks and
 routes
 >         line_width            Width of lines, in pixels
 >         line_color            Line color, specified in hex AABBGGRR
 >         floating              (0/1) Altitudes are absolute and not
 clamped to ground
 >         extrude               (0/1) Draw extrusion line from trackpoint
 to ground
 >         track                 (0/1) Write KML track (default = 0)
 >         trackdata             (0/1) Include extended data for
 trackpoints (default = 1
 >         trackdirection        (0/1) Indicate direction of travel in
 track icons (defau
 >         units                 Units used when writing comments
 ('s'tatute or 'm'
 >         labels                (0/1) Display labels on track and
 routepoints  (default
 >         max_position_point    Retain at most this number of position
 points  (0
 >       gpx                   GPX XML
 >         suppresswhite         (0/1) No whitespace in generated
 shortnames
 >         logpoint              (0/1) Create waypoints from geocache log
 entries
 >         urlbase               Base URL for link tag in output
 >         gpxver                Target GPX version for output
 >         humminbirdextensio    (0/1) Add info (depth) as Humminbird
 extension
 >         garminextensions      (0/1) Add info (depth) as Garmin extension
 >       vpl                   Honda/Acura Navigation System VP Log File
 Format
 >       mapsend               Magellan Mapsend
 >         trkver                MapSend version TRK file to generate (3,4)
 >       magellanx             Magellan SD files (as for eXplorist)
 >         maxcmts               Max number of comments to write
 (maxcmts=200)
 >       magellan              Magellan SD files (as for Meridian)
 (maxcmts=200)
 >       magellan              Magellan serial protocol
 (maxcmts=200)
 >         baud                  Numeric value of bitrate (baud=4800)
 >         noack                 (0/1) Suppress use of handshaking in name
 of speed
 >         nukewpt               (0/1) Delete all waypoints
 >       nmea                  NMEA 0183 sentences
 >         snlen                 Max length of waypoint name to write
 >         gprmc                 (0/1) Read/write GPRMC sentences
 >         gpgga                 (0/1) Read/write GPGGA sentences
 >         gpvtg                 (0/1) Read/write GPVTG sentences
 >         gpgsa                 (0/1) Read/write GPGSA sentences
 >         date                  Complete date-free tracks with given date
 (YYYYMMD
 waypoint
 >         pause                 Decimal seconds to pause between groups of
 strings
 >         append_positioning    (0/1) Append realtime positioning data to
 the output fil
 >         baud                  Speed in bits per second of serial port
 (baud=4800
 >         gisteq                (0/1) Write tracks for Gisteq Phototracker
 >       ozi                   OziExplorer
 >         pack                  (0/1) Write all tracks into one file
 >         snlen                 Max synthesized shortname length
 >         snupper               (0/1) UPPERCASE synth. shortnames
 >         snunique              (0/1) Make synth. shortnames unique
 >         wptfgcolor            Waypoint foreground color
 >         wptbgcolor            Waypoint background color
 >         proximity             Proximity distance
 >         altunit               Unit used in altitude values
 >         proxunit              Unit used in proximity values
 >       wbt                   Wintec WBT-100/200 GPS Download
 >         erase                 (0/1) Erase device data after download
 > Supported data filters:
 > - and a little test with a small gpx-file of a garmin-gps:
 > C:\wd\mg>gpsbabel -i gpx -f ask_bayern_ll_wgs84.gpx -o gpx -F
 testgpsbabel.gpx
 > GPX: This build excluded GPX support because expat was not installed.
 > so it seems that Jürgen's updated version didn't find its way to the
 officinal osgeo4w-stack?
 > and see a message in the osgeo4w-ML:
 > http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-September/001062.html
 >  ... of putting a copy on osgeo4w that very likely is going to get out
 of date.
 > what would be the best way to get this working for the WinGrass-builds
 and WinGrass-build-environment?
 > replacing osgeo4w's gpsbabel with a copy of
 http://www.gpsbabel.org/download.html?
 > IMHO gps-data is nowadays a very important data source which should be
 imported as default to any gis-software.
 > best regards
 > Helmut
 what I've done:
 - experimentally I've copied the latest exe from
 http://www.gpsbabel.org/download.html to c:/osgeo4w/bin:
 testgpsbabel.gpx
 works without any problem.
 - I've copied the same exe to C:\Program Files\GRASS-65-SVN\extrabin and
 tested v.in.gpsbabel in a WGS84-ll-location:
 v.in.gpsbabel input=C:\wd\mg\ask_bayern_ll_wgs84.gpx
 output=testvingpsbabel format=gpx
 No features requested for download. Assuming waypoints.
 Loading Waypoints from <C:wdmgask_bayern_ll_wgs84.gpx>...
 GPX: Cannot open file 'C:wdmgask_bayern_ll_wgs84.gpx'!
 c:/Program Files/GRASS-65-SVN/scripts/v.in.gpsbabel: line
 271: C:\gisdata\grassdata/wgs84gc/user1/.tmp/1192.0.xcsv: No
 such file or directory
 271: [: : integer expression expected
 ERROR: Error loading data from gpsbabel
 so there seems to be a path-problem:
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1171#comment:5>
