[GRASS-dev] Re: [GRASS GIS] #1171: wingrass: include a gpsbabel with XML support
GRASS GIS trac at osgeo.org
Thu Sep 23 13:24:33 EDT 2010
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  enhancement         |      Status:  new
 Priority:  normal              |   Milestone:  6.4.1
Component:  Packaging           |     Version:  svn-develbranch6
 Keywords:  gpsbabel, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-64              |
Comment(by hellik):
 Replying to [comment:6 hamish]:
 > try quoting the input file name, the \x is being treated as a literal
 character "x", not "\" and "x".
 > -input=C:\wd\mg\ask_bayern_ll_wgs84.gpx
 > +input="C:\wd\mg\ask_bayern_ll_wgs84.gpx"
 > what terminal is this from? (I'd expect it if unquoted from sh/bash)
 > Hamish
 tested as quoted in the wxgui:
 v.in.gpsbabel -w input="C:\wd\mg\testgpsbabel.gpx" output=test2 format=gpx
 Loading Waypoints from <"C:wdmgtestgpsbabel.gpx">...
 GPX: Cannot open file '"C:wdmgtestgpsbabel.gpx"'!
 c:/Program Files/GRASS-65-SVN/scripts/v.in.gpsbabel: line
 271: C:\gisdata\grassdata/wgs84gc/user1/.tmp/5640.0.xcsv: No
 such file or directory
 271: [: : integer expression expected
 ERROR: Error loading data from gpsbabel
 it doesn't work neither with a quoted path in the wxgui. the path-problem
 remains.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1171#comment:8>
