[GRASS-dev] [GRASS GIS] #1175: g.html2man.py bug
GRASS GIS trac at osgeo.org
Fri Sep 24 03:59:29 EDT 2010
 Reporter:  neteler    |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:             |    Platform:  All
      Cpu:  All        |
 In a series of module but not all the following problem happens
 during compilation (long lines broken here for readability):
 VERSION_NUMBER=7.0.svn /home/usr_local/src/grass70/dist.x86_64-unknown-
 linux-gnu/tools/g.html2man.py
  /home/usr_local/src/grass70/dist.x86_64-unknown-linux-
 gnu/docs/html/db.copy.html
 gnu/man/man1/db.copy.1
 gnu/docs/html/db.copy.html:80:0:
  Error ({}):     <li><a href="#SEE ALSO">SEE ALSO</a></li>
 make: *** [/home/usr_local/src/grass70/dist.x86_64-unknown-linux-
 gnu/man/man1/db.copy.1] Error 1
 make
 gnu/docs/html/ps.map.html
 gnu/man/man1/ps.map.1
 gnu/docs/html/ps.map.html:65:0:
  Error ({}):     <li><a href="#border">border</a></li>
 gnu/man/man1/ps.map.1] Error 1
 I suspect that "#" is causing troubles.
 Using
 Python 2.6.5 (r265:79063, Jul 14 2010, 13:38:11)
 [GCC 4.4.3]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1175>
