[GRASS-dev] [GRASS GIS] #1178: WinGrass: g.extension - problem with
path to $GISBASE
trac at osgeo.org
Sat Sep 25 11:16:01 EDT 2010
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
a self build WinGrass64svn-installer (svn-client included):
on the msys-commandline:
GRASS 6.4> g.extension extension=r.stream.order
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order\main.c
A r.stream.order\description.html
A r.stream.order\global.h
A r.stream.order\io.c
A r.stream.order\order.c
A r.stream.order\Makefile
Checked out revision 43684.
Compiling <r.stream.order>...
Makefile:12: c:/Program: No such file or directory
Makefile:12: Files/GRASS-64-SVN/include/Make/Module.make: No such file or
directory
make: *** No rule to make target
`Files/GRASS-64-SVN/include/Make/Module.make'. Stop.
FEHLER: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory
`C:\\gisdata\\grassdata/wgs84gc/user1/.tmp/7992.0/r.stream.order':
Permission denied
GRASS 6.4>
there seems GISBASE=c:/Program Files/GRASS-64-SVN isn't recognized because
of a whitespace in the path?
and from the wxgui:
g.extension --verbose extension=r.stream.order
svnurl=https://svn.osgeo.org/grass/grass-addons/ prefix=$GISBASE
Tut mir leid, <Files/GRASS-64-SVN> ist keine gültige Option
Sorry, <Files/GRASS-64-SVN> is not a valid optiopn
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178>
