[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Sun Sep 26 11:07:01 EDT 2010
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:6 glynn]:
> Replying to [comment:3 hellik]:
> > with added -x in the first line:
> Makefile:12: c:/Program: No such file or directory
> Makefile:12: Files/GRASS-64-SVN/include/Make/Module.make: No such file
or directory
> Makefiles can't handle spaces in filenames, and this is rather
fundamental to the way make works. Spaces separate tokens, and there isn't
any (documented) mechanism to quote spaces.
> If the variables were only used in commands, you could quote them, but
that won't work elsewhere (e.g. "include" statements or dependencies).
> The only workaround I know is to use 8.3 names (e.g. "/c/progra~1"
rather than "/c/Program Files"), but I don't know how to perform that
conversion from within a script (from C, you can use GetShortPathName()).
would a little bat-script on the windows-command-line help?
%~1 - expands %1 removing any surrounding quotes (")
%~f1 - expands %1 to a fully qualified path name
%~d1 - expands %1 to a drive letter only
%~p1 - expands %1 to a path only
%~n1 - expands %1 to a file name only
%~x1 - expands %1 to a file extension only
%~s1 - expanded path contains short names only
%~a1 - expands %1 to file attributes
%~t1 - expands %1 to date/time of file
%~z1 - expands %1 to size of file
%~$PATH:1 - searches the directories listed in the PATH environment
variable and expands %1 to the fully qualified name of the first one
found. If the environment variable name is not defined or the file is not
found by the search, then this modifier expands to the empty string
The modifiers can be combined to get compound results:
%~dp1 - expands %1 to a drive letter and path only
%~nx1 - expands %1 to a file name and extension only
%~dp$PATH:1 - searches the directories listed in the PATH environment
variable for %1 and expands to the drive letter and path of the first one
found.
%~ftza1 - expands %1 to a DIR like output line
for example param.bat:
@echo off
echo %%~1 = %~1
echo %%~f1 = %~f1
echo %%~d1 = %~d1
echo %%~p1 = %~p1
echo %%~n1 = %~n1
echo %%~x1 = %~x1
echo %%~s1 = %~s1
echo %%~a1 = %~a1
echo %%~t1 = %~t1
echo %%~z1 = %~z1
echo %%~$PATHATH:1 = %~$PATHATH:1
echo %%~dp1 = %~dp1
echo %%~nx1 = %~nx1
echo %%~dp$PATH:1 = %~dp$PATH:1
echo %%~ftza1 = %~ftza1
a little test with following installation path "C:\Program
Files\GRASS-64-SVN\"
C:\wd>param.bat "C:\Program Files\GRASS-64-SVN\"
%~1 = C:\Program Files\GRASS-64-SVN\
%~f1 = C:\Program Files\GRASS-64-SVN\
%~d1 = C:
%~p1 = \Program Files\GRASS-64-SVN\
%~n1 =
%~x1 =
%~s1 = C:\PROGRA~1\GRASS-~2\
%~a1 = d----c---
%~t1 = 25.09.2010 16:56
%~z1 = 4096
%~$PATHATH:1 =
%~dp1 = C:\Program Files\GRASS-64-SVN\
%~nx1 =
%~dp$PATH:1 = C:\Program Files\GRASS-64-SVN\
%~ftza1 = d----c--- 25.09.2010 16:56 4096 C:\Program
Files\GRASS-64-SVN\
C:\wd>
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:7>
